901 LS into a 93 LS >.. wiring is way different?
    My dad just called and said he was looking at our planned swap (timing belt etc coming tuesday) and he says a lot of the connectors are way different -- round vs oblong, etc... is this true?
    the 90 is OBD-0, the 93 is OBD-1. connectors for some stuff is different. read the motor swap guide in the teg tips - will explain OBD stuff.
      you need to use your 90-91 dist. and injectors..everything else should be ok
        then u would need the 90-91 resisterbox
        since its 90-91 engine to 93 car
        try to use 93 injectors/distruator ...
        wiring should match up
          ok, which ECU? The 93 auto or the 91 stick?
            you will need to use the 93 obd1 auto, are you doing auto/manual conversion also?. Buy intake manifold gasket and install 93 intake manifold onto 90 block, you do not need to use your 90 injectors or distributor [just give them to me j/k]. The engine harness might also need to be swapped to plug in the distributor and such [obd1]. One last thing is sensors, plug them all back in while the motor is out, belive me it is a pain to do this while the motor is installed as you could imagine. I am close I could help.
              right on, that'll help a lot. The stuff I don't use I can use to put my rebuilt 93 into my brother's 91, right? The opposite parts (IM, harness, inj/distributer) ?
                #8
                not if you give them to me.
                  #9
                  yo, hit me up on aim ( irresponsibleOT ) about that underdash wiring harness
                    #10
                    no aim!? email me and I can email you with my number. Thanks
                      #11
                      [email protected]
                        #12
                        [email protected]
                        woops
                          #13
                          YGM homie
                            #14
                            It sounds like you're putting a '90/'91 engine into a '93...
                            If you're in CA, you may not be able to pass smog -- I think you can only put in engines newer than your chasis. Just something to look into before you do the swap.
                              #15
                              that's what i thought too, but now i'm told as long as the motor was still offered in your year you're ok -- so i could put it in a '98 even
                              but that would be even worse
