I took off both of the small bolts under the transmission but only a little fluid is draining out and it is doing so slowly. Am i doing it right and anyone have any tips
What bolts did you take off? The drain and fill bolts are actually fairly large so you may have taken off the wrong bolts. The drain bolt is taken off by using a 3/8 drive ratchet, just the ratchet without a socket attached.
