I am changing the tranny fluid in my 91 automatic and i cannot find the drain bolt
Found the bolt but i cannot get the damn thing off
i found the bolt but it is a bitch to get off. Its also good because i saw the inside of the tire and i need a new one because the steel belt is poking through
there are two bolts on the tranny, the lower one is to drain and the top one is to fill i believe. there is an easier way to fill up tranny fluid though. just unbolt the speed sensor and put it to the side and fill it up through that hole.
fill it through the dipstick
