i recently put a new fuel pump in and when it was all done the pump would not turn on so i have hooked the pump up to a switch running from the battery. So know the pump turns on but car still wont start. Its not getting spark know. I thaught it could be my ecu. Can someone give me some good advice. and also how could i fix the pump problem to
well on my GSR, when i was not getting spark it was my distributor, i had to change that. as for the fuel pump, try checking the main fuel relay…hope this helps.
main fuel relay is fine. i bought a new distrubater about 8 months ago.
