Fuel Pump replacement
I need a fuel pump. I am looking around. I found a Walbro high pressure 255 lph fuel pump. Will that work with an all stock engine?
yes it will work. i have one in mine the only thing i recommend is useing the stock teabag thing because mine acts alittle weird when it gets down to about 1/4 tank. and ive read posts where they went back in and put the stock teabag and it solved their problems. i just havent got up to doing that just yet though.
Yeah, the Walbro is definately a good unit. What Problems have ppl had w/ the walbro teabags, though?? Mine seems to work fineā€¦
What kind of problems have you had with the walbro teabag?
like instead of the gas running out at an empty tank it will run out at like a quarter tank. there was another post here somewhere where he said he had the same problem and he put the stock one back on and it worked great.
