Anyone know which fuse to pull to disable the ABS system? My pump keeps cycling and I want to turn it off here at work
I had to pull two of them from under the hood. One blue (15 I think) and one yellow (20). I dunno if that helps you any though.
you don’t have the positions in the fuse box? are both under the hood?
I don’t have the positions…I took them out a while ago and now I forget. Both were under the hood though…I think. I’m starting to doubt myself now. HAHAHA! I’m almost positive they were both under the hood.
Just swap the lines. You already have the kit.
lazy
Just open up the fuse box under the hood and it’ll tell you which ones. Then get rid of that ABS…
there is no indication on my fuse box… anyone with the position please
DP, missionary, doggy :shrug:
Here you go:
:shock:
:shock: :shock:
Hey nino… look what duy is doing to you for helping me out :shock:
:uhoh: :run:
You mean there IS something the great schu doesn’t know?!!!?!
v
16… hahahahahahahahahaha, it was not a knowledge question… it was a information question
Must be the only bandwagon people are not criticized for jumping on.
Misguided little childern should not play with fire
