Okay, just did a compression test while changing out the plugs & wires on my '92 GS. My B18A test results are:
132 125 110 110
I liked the fact that the numbers were all in all pretty close to one another, but are they all sort of low in general? Or is that what they should look like for a B18A w/ 169,000 miles on the clock?
Ouch that is pretty low. Are you sure that you did the compression test correctly? Did you crank the car 6 or 7 times or until the needle in your gauge stopped climbing?
And yes, 185 +/- even 25 is good/ok, as long as your numbers are consistent.
Yeah, I pulled all the plugs & wires, then starting from the #1 cylinder, i cranked the car until the needle stopped moving. What could be causing these low numbers? I have no oil consumption or coolant consumption at all…why would it be low accross the board like that?
You need to do the test when the engine is hot and you have to press the gas pedal to the floor to let air go into the cylinders… that’s prolly why the numbers are that low
