[QUOTE=snowman2805;2072043]if your going H2B in your DA QSD is the only company to my knowledge that makes the kit for our cars. and if not they are the best. (in my opinion) With that being said be prepared for anywere between a 1.25 - 2inch gap in the hood as the H22 is a larger motor than our Bseries motors, and with the QSD kit they built the kit to keep the trans in the stock location so hood clearance is compromised. the only way about it is to cut the skeloton out of the hood (which only drops it alittle), cutting a hol in the hood and installing a custom scoop, a custom hood, or just dealing with it.
If you can get past the hood clearence the swap is really no different than an other swap. with H2B the only thing you use from the H family is the motor, so everything else is all Bseries, so clutch, flywheel, axles, etc. another thing with the QSD kit is you must shave down the back of the block around the oil pan area in order for the intermideate shaft to clear the motor. you will want to look into shaving the crank pully down to a one belt, just for the alternator, removing the balance shafts, and relocating the pcv valve. even with all that done you will more than likely have to move the alternator down with a relocation kit, theres plenty of options for that out there, and still may have to BANG the frame rail in some in order for the motor to clear. also look into a custom header for the swap. as the Hmotor in its origanal state is slanted toward the rear of the car, but with the trans not moving the H22 is slanted forwarded, this points the header exit up toward the powersteering rack. you can always get a normal H header and heat it up and bend it, but i dont like that rought.
Wiring wise, you use your B series harness and just wire it to the H motor. not to hard. theres two ways to do it, my recomendation is that you label the harness before you pull it off your Bseries and that way you can work easier when installing it onto the H. the other way is to sit the motors back to back and just swap the harness one sensor at a time. if your car is not Vtec you will need to wire in Vtec to the ecu you choose to go with. i wont get into that there is too much info on the net for that. Depending on the ecu you choose, depends on if you have to wire knock or the iabs. if you get a P28 and have it chipped, which is what i recomend if not runnung a Hondata, you will not have to wire these things as that ecu dont look for it. Obviously you will have to convert to OBD1 if not already.
Im sure theres some things im missing, i just did this off the top off my head. ive put H22s in many cars, im currently putting an H22 in my boys civic, its a straight H swap though. when im done with that i will start my H2B build. all though im in no rush to finish it. you need to do more research on the H2B swap and really decide if its right for you. if so get it started and post your progress on the board and im sure we will all help you when you get stuck. but i just gave you a good place to start now go use your GOOGLE[/QUOTE]
wow thanks do appreciate and trust me i have searched alot about this build part of my wiring issue is 1. before my teg was stolen it did have a b16 with a obdo to obd1 jumper harness that was taken along with the motor and the harness 2. its going to be a rebuilt usdm h23 block with a rebuilt usdm h22 head i have both the h23 wiring harnes and the ecu i believe all need is another ls harness according to one guy off honda-tech 3. explicit speedmakes a full kit that helps remove the whole shaving part out of the picture with a different front cross member and all brackets to the swap 4. i have heard that i can use accord axles but what year i do not know just what i heard but i agree that i havent thought about the hood and the issue of it being raised or what not lol i have spent alot of hours looking on every possible pro and con not to do this swap and being that most of the parts minus trans and top dollar parts needed has been generously donated to my cause but thank you for your wise insight i gives me better understanding of what im doing and what else i forgot about and thanks to everyone that has answered any more help will be greatly appreciated and yes i do plan on doing a full build write up and i will for sure be keeping you guys in the loop as it progresses
