quick question a ctr trans was cable and an obd0 motor? will the clutch fit in a 91 ls trans since it is the same years and both were cable trans? if this make sense…
im sorry man but your question makes no sense… a ctr trans was cable and it was on an obd0 engine?.. engine has nothing to do with a clutch… if what you are asking is if a clutch that was used in a CTR trans that was mated to an OBD0 engine will work on your ls tranny… then the answer is simply NO. clutches that are for HYDRO b series trannys are ONLY compadable with one type of cable trans… and that is the 92-93 integra YSI trans… short and long geared. hope that answered your question man… not here to make you feel stupid… we are all just here to help just please explain your self better in the future
ok yea i mess it up lol, but i said nothing about hydro, both are cable trans andthe clutches do not use the same spines? if this make any sense lol
and :search:
ctr is a hydro trans, not cable. so no it doesn’t make much sense. what trans are you really trying to talk about??
my fault for confusion my bro told me it was a ctr and its not its an sir tran im so sorry for my ignorance i did search if i missed it tell me where the forum is
1990-1991 (A1, S1, Y1, J1) - smaller spline on the transmission input shaft, uses the specific 90-91 clutch
1992-1993 (YS1) - larger spline on the input shaft, uses the same clutch disk as 1994-2001
Any 1990-1993 throwout bearing will work and any 1990-2001 flywheel and pressure plate will work.
Your transmission should have a label on it that says which one it is (located right next to where the code is on the engine block when installed), but if it does not have a label on it, look for the following…
on the bottom side of the transmission, 92-93 has these two bolts:
90-91 does not have them:
