b16a what cams are the best for all motor
i just put itr cams in i have gsr to are the ctr better what do u people think
ctr intake cam and type-r exhaust 00-01. if its complety stock internaly. if you dont have the dual valve springs on the exhaust side get them and run the type r cam.
the ctr and 00-01 itr intake cam is exactly the same. now the eariler itr cams have 3 degrees less of duration compaired to the ctr cams. on both the ctr and itr exhaust cams they have the identical numbers for both. for a cheap and effective setup i would get some b16 dual valve springs (later model heads) swap them to the exhaust side and run the itr intake dual spring setup. at most from acuraoemparts i calculated 80 dollars for the dual spring setup, or jsut get some portflow inner springs.
