Ive already searched but no hits on my question.
Im looking for a way to add a auxilary rpm shift light in my dash without haveing to use a rpm monster tach of any kind. I just want to add a LED bulb and have it flash on when i set it to a preset rpm…
anyone ever done this or have any idea what i could use to get something like that going. Ive thought of maybe useing a vtec controller but dont really know if its possible or not.
Buy some thing like this http://www.summitracing.com/parts/SUM-G2945/?image=large Mount it under the dash, disconnect the light and solder in the leads for a remotely mounted LED.
yeah this is what im looking for but would msd make anyhting like this or would i just need to order it from summit… reason i ask theres a shop that can get me almost any part i want if its from msd.
this shift light would be perfect if it flashed in red or yellow…
http://www.msdignition.com/Products/RPM/Timing_Controls/RPM_Controls/7552_-_LED_Shift_Light.aspx
you need MSD’s rpm activated switch also
that shift light does light up red.
Ive seen people use a normal shift light and put it were there cigarette ligher is normally i know thats not the answer to your question but i thought it was pretty cool because it had a cap to cover it up so i wouldnt be lighing up at night
