I got my High comp B20b from www.hmotorsonline.com for $1000 shipped. I absolutely love this engine! Great response, pulls hard, (chirps tires in 1st, 2nd, 3rd!) & pretty quick to boot. I highly recommend you get your engine from hmotorsonline. They are the #1 importer & NO ONE has any complaints about them. Mine was almost brand new looking inside.
Check it:
I swear it seems like it was barely driven. The seals & gaskets were brand new, (or @ least they seem that) & the exterior was immaculate. You could tell they didn’t clean it themselves cause there was some dirt on the bottom of the intake manifold from some up splash. However, it still looked new! Buy from them & you too will get a stiffy when your engine arrives!
As for the horsepower numbers, the 147hp/135tq is a little off. It’s more like 160hp/ 140tq. 147 crank hp is like 128 to the wheels.
The reason for this is that the B20b is in a heavy ass van/SUV w/ a sluggish auto transmission & a bunch of power starving emissions components. When the engine is put in a lighter car w/ a better geared manual trans, the power is uncorked.
Here is a dyno chart from a G2 member w/ a high comp USDM B20Z in his teg :
The only mods were intake, header, 2.25" exhaust, a lightweight flywheel, & a street tune w/ CHROME. 146hp/137tq to the wheels! You can’t get these numbers on a street tuned engine w/ mild bolt-ons that only baselines @ 147 crank hp. Not to mention, this is a lower HP USDM B20z high comp; so imagine the numbers available w/ a JDM high comp B20b! The owner said he could have probably could have gotten closer to 150 w/ a high flow cat.
I have intake, 4-2-1 header, high flow cat, & 2.25" exhaust on mine now. I will be adding a better flowing SP header w/ a 2.5" collector, 11lbs flywheel, a Blox intake manifold, & getting a street tune in the future. The goal is 165-170 hp to the wheels. It should be a very attainable w/ this setup.
As others have stated, this engine is a great platform for some serious power. Get the proper bolt-ons first, then enjoy. Later on, you can turbo or Vtec it. Or both!
BTW- a stock JDM high comp B20b in a DA will beat a stock 99 Civic SI. Youtube it!
In conclusion- JDM high comp B20b FTW!!!
:getsome::manual:
Figure that out!
