Engine Build-Opinions
    Tired out b17a1 needs a build here is what i want to do:
    B17a1 block
    B16a crank
    B17a head
    B16b pistons - jdm pct
    B17a1 rods
    Oem headgasket
    I figure out:
    9.51:1 static
    9.31:1 effective
    1595.3 cc displacement
    1.71:1 r/s ratio
    0.072 piston deck height
    Trying for max rpm with stock short block components. This combo seems like the only one that will work with this block/crank combo.
    Only reason for b16a crank is cause b17a1 crank is damaged beyond repair
    Just looking for insight on b16a crank into b17a1 or whatever comments you guys may have
    I dont think u can use the p61 rods on the pr3 crank.
      explain why noob.......
      I want truthful experienced info
        find another crank. you wont make power past 8k if that with your combo/compression.
