1: Yes, but it’ll be slower then your stock B18A. You need the proper tranny
2: That would be your cross member. stock ehader clears it fine.a few other headers hit it so you ahve to notch out a piece of it, you canot simply remove it. You need it.
3: DC JDM ITR 2.5" collector. This requires notching the memebr I’m pretty sure.
4: Yes
5: Most thigns are a direct swap over. what year is your teg and what year is the motor?
you said you searched, but i don’t think you searched very well if you actually did at all. if you had, you could have answered all of those questions.
i currently have b16 with p28 and hondata s100. running with 91 ls tranny.
i made 148 @ the wheel/106 tourqe with no intake or what ever bolt on upgrade. i never complain and love having longer gear then short gear tranny. you will hardly notice the difference.
now im making about 161 @ the wheel with just recently replace the tranny with 93 tranny case with 99 internal ls tranny.
short gear allow you to accelerate a little quicker.
niskyspy…i think you should try to drive both car. civic si coupe and vtec motor with ls tranny…then you decide.
From my experience LS tranny on a B16 is a bad match. and the chances of him finding someone with a civic Si coupe with the b16 with an LS tranny is rare sicne they are also the shorter geared trannies stock.
Well I will probably go with B20 but still, when I asked if B20B will be faster than B18A Tchleung said it will be faster. But B18A had 130HP and B20B has 126HP and a little bit more torque why would it be faster?
And one more question, how can I make B20B have the same amount of HP as B20Z isnt the only difference between them compression?
falling out of vtec is not a problem. vtec kicks at 5500 rpm and feel full power start at 6000 rpm. i did the test before and after tranny swap… 2nd gear goes to a little over 70 mph and 3rg goes over 110 mph…im sticking with n/a for another 6 months then go full boast…and every set up or mods done is all depends on what the owner wants out of it…
Its got a GSR head (bigger cams, slightly higher CR) and I take out other LS’s without much problem. I was door to door with a stock ITR the other day for the entire race (40mph to about 80mph) before my Hondata went in. I have I/H/E/no cat/clutch and fly combo (now its tuned)
The header is the base model chikara proven to lose horsepower, BTW (It was a gift, blow me)
Its not slower than a stock B18A unless its at low RPM. After 5k I walk B18A’s and B18C1’s. Below that…im lunch. The B16 will never “feel” as fast because of the complete lack of torque.
My 1/4 time is slower than what it used to be, but the trap speed is higher.
I have a 1990 ls with a b16a and a ls tranni, i smoke b18a tegs all the time even have taken out dohc zc crxs and ls hatches. i have a pwo ecu and my vtec kicks at about 4800rpm, i have header, intake, full 2.5" exhaust with no cat, short shifter. its alot faster than my old ls and i like the powerband, vtec is definatly kicking in 2nd when i shift at 8200 rpm lol, dam redline, hop to be puting some more goodies in the engine soon like, type r cams and springs, skunk2 intake mani, 8 pound flywheel and ctr cams, i like b16a all motor, when u see a friend that has a built all motor b16 98 hatch beat a 93 tt rx7 by 5 cars uve see everything, oh ya the rx7 is modded lol. 1 more thing ls trani is good for comuting also, im at like 3,100-3500 on the freeway in 5th.
some1 help me, i need parts for my engine and i need my ecu chipped its a pw0, im building a all motor, any used or new parts for cheap will help, i have turbo things to trade-- rebuilt t3, bov, piping ect… email me hondasarebadass@yahoo.com
