i was wondering since im gonna be running .25 over ctr pistons and 310cc injectors which obd should i use obd-0 or 1
thanx
thanx
Which obd you run isn’t going to be dictated by what pistons and injectors you’re using…
If your car is a 90-91, then you have an obd0 car. You can run your setup like that unless you wish to convert to obd1.
If your car is a 92-93, then you have an obd1 car, and in which case you’ll want to keep it obd1.
mines is a 92 so i guess i should jus leave it that way rite
Unless you can think of a good reason to change it… I sure can’t.
