Hello. I’ve got a set of 11.5:1 SRP pistons in a 0.5mm bored over B18a1, making a total bore of 81.5 mm. (Or equivalent to 3.20866 inches.) The engine burns oil, and I’m changing out the piston rings. Now, after we hone the cylinders, would I still use 3.209" (+0.002) piston rings, or should I use a slightly bigger sized ring to compensate for the new hone?
In terms of the piston ring I am replacing the part number is as follows:
SRP Piston Rings: 867-JXC0F4-32092
Ring specs are as follows:
top ring: 1.0 mm
2nd ring: 1.2 mm
3rd ring: 2.8 mm
The LSvtec came WITH the car when I bought it a few weeks ago. The original owner bought the block off of ebay. And thanks for the advice. I actually was planning on having the bum sleeping at a bus stop hone my engine cylinders.
it’s not just the hone either…not being properly broken in will cause poor ring seat. but hey, if it’s fucked up this time at least we’ll know for sure it was your fault.
