B18c5 On 93 Integra Gs 2dr Hatch ***Help***
The Car it is going in: 93 Integra Gs 2 dr Hatch
I’m planning to get the b18c5 and i was wondering if i can just drop it in with out any modifications since it’s a B-Series.
Since i have the p72 for my B16a which i currently have in right now
would the Type R ecu just plug in? with out any modifications or ?
And about the axles, which one’s would i use?
Would i be able to use the Type R tranny(Hydro) or do i have to use a cable trans?
i want to know what to do before i do anything…
:bump: so i can get some help… :slight_smile:
like i asked on honda-tech, what obd is the motor? what obd is the ecu?
and you’ll have to use a cable tranny unless you plan on doing the hydro conversion. just search around, you’ll find a lot.
the motor is OBD 1 well, it’s an 2000 type R motor (usdm)
the ecu that i have is OBD 1 (p72)
when i buy the stuff it’s coming with:
Motor+Trans+Ecu
i believe the B18c5 is obd 2
so, im going to convert it to obd 1
hey man, i just got your pm on h-t. um…unless you plan on changing all the sensors on the motor to obd1, you’d have to attempt using an obd2 harness, then jumping it at the ecu.
Please read the swap guide in the teg tips section. It will help you immensely. If you have any questions after that, send me an e-mail. I’ll give you a hand.
