het does any one know if a 94-2001 ls oil pan will fit on are cars with no mods. i was looking at this oil pan for my ls. i know it will bolt up but will it hit stuff in are car will it work with are headres.thanks :auto:
putting a motor in your g2 is diff than putting an oil pan… cuz the motor is the whole thing and the motor mounts just line up… whereas the oil pan could be only for the g3… i dont know if it fits or not but i wouldnt go with buddies advice just yet until someone here knows for sure or you find out for sure… just look up the part numbers from honda/acura then you will know.
