ls/vtec ecu and yes i searched
i have a 93 teg and i am putting on a 95 up gsr head. what ecu should i use. and no i dont want to use a p28.
you didn’t search hard enough.
http://www.g2ic.com/tegtips/engine/Engine_Swap_Guide.doc
Why wouldnt you want to use a p28? There easy to find, they dont require knock sensors, and they can be rechipped to run dohc. Thats what i was running when i had my teg, chipped p28 w/ skunk2 program. If you decide to use a gsr then you’d have to rig up your own knock sensor. If not, your car will throw a code. Besides with a chipped ecu, you can change programs as often as you like.
