Coolent Necks Interchangable?
I am wondering if I can swap out my coolant neck, the one that the upper rad hose goes to on the side of the valve cover on my 96 b20 with a 91 b18 so that i can have a bleeder screw…
Thanks
all b-series should be interchangable.
when i changed my b16a head to a b18c1 head i found out they used different water necks.
Im pretty sure that VTEC water necks wont changeover to non-VTEC engines.
Ok i changed it out, and yes they are interchanable. A 91 B18 water neck will swap with a 96 B20
Thanks everyone
Yes, the same basic design of the head is the same.
