The b18c1 that I rebuilt and isntalled myself in the DB2 has big problems. Most pressing issues are:
Burns oil when first started.
Leaks oil from head gasket.
Pings at WOT above 4k.
I am running this on the stock computer, 1824 cc of displacement and 8.8:1 compression on JE forged slugs with eagle rods. I did all of the work myself except for the machining. The head was resurfaced and secured to a new OEM head gasket using arp headstuds and copper spray.
What could be causing the oil leak?
What can I do in the sort term to fix the pinging?
Why is it burning oil when I start it?
Does anyone in northern new england have enough spare time to help out a poor college kid who might have to give up his teg if he can’t fix it?
I would guess it burns oil when its cold becuase of the forged pistons clearances being too loose, then when they warm up they expand and seal properly. This is just a guess, not gospel.
Where from the HG are you leaking oil? I thought I was leaking in the front left corner, but it turns out my VTEC Solenoid is just a bit leaky.
