ok i put a b16 in my integra a month ago and i wanted to get all the vacuum hooked up i took the rail from the b18 and put it on i was wondering there is some hoses left were do they go does anyone have a picture of how they did it or a drawing?? im trying to figure out why im only getting 200 mi per tank of gas its bugging me my first tank of gas throw it was 300 mi im wondering if it could be the injectors?? or fuel pump??
thanks
justin
i used the rail from my b18 also and all the lines hooked up fine. look on the underside of your hood, there is a vaccum diagram there.
i have an aftermarket carbon fiber hood on it so there is no diagram
look about half way down on the page. that helped me a lot when i did my swap. hope that helps
Im getting ready to swap my turbo built b16 into my DA but I used an aftermarket intake manifold and I only have two vacuum sources on the back of it
- for the breakbooster line
- all misc vacuum lines
So…
What do I do? Just make sure all the vacuum lines are connected with multiple t’s?
I went from obd0-obd1 are there some vacuum lines I dont need?
Any info would be great
