Ok check this out i turn on my car right then once i let it heat up the rpm’s is to high its right above 2,000 so i started to messed with that little screw right on the throttle body well all i know if u move it backwards the rpms goes up and if moved forward the rpm’s lowered well the screw is moved all the way forward and it cant go no further and the rpms is still up, has anyone had this problem and on how to fix this matter any suggestions help!!!
It could be a number of things. See if you have a vacuum leak and I would leave the screw where it was if this is just a recent problem.
found out what it waz it waz my throttle body it waz jacked up so i put in a gsr one and it rocks thanx guys for the info :manual:
