how many miles should i do to properly break in itr cams? milage/rev range?
When I broke mine my CTRs in, my friend did it for 15 min at 1500 rpms.
There is not a break in period per say, but proper installation is KEY. Make sure to use a cam or assembly lube of sorts when installing the cams. Be very liberal with the application. Make sure to torque the cam holders in the right order and let the car warm up before taking it out for a spin. Listen for incrorrectly adjusted valves or any unusual noises. Then go test them out.
