can any one give me some pointers on correcting the idle on my 90 b16a w/ itr cams. so far ive got the ign. timing and idle adj. screw in check. im gonna adjust the thr.cable soon. but it still idle below spec(750+or-50rpms).
Reset the ECU, obviously. And did you set your idle, or just twist the screw? Because there is a difference.
Setting the idle, there is a procedure, before turning the screw. I think member XDEEP wrote it out once. Its pretty simple.
