my engine is built w/je 10:5:1’s…im looking to go LS vtec w/b16 head…is that possible or will my compression be too high for the street?
i dont this is will be at all …just get it tuned and you shouldnt have any problem …i know and have seen people run as high as 12.5-13.0 comp tuned on 93 on the street safely …there are prob some people with even higher …its all in tuning and engine management …
ive already got rc310 injectors and aem fpr…what else would be necessary
i emailed you
as for your motor your compression w/ your j/e’s + b16 head will be about or around 11:1. definitely safe for 91 octane.
Anthony
efi101 certified
www.EFI101.com
special tuning services available
what are you using to lean out the larger injectors? i would buy a set of stock injectors.
