which is better, buying a b18 and boreing it to a 2.0 or just buying a b20?
if it helps i am planning on doing ls/vtec or cr/vtec to it, and eventual JR supercharging
is this going in a G2? because the brake booster is in the way of using a JR supercharger. otherwise, you probably want stronger sleeves for the power you want, in which case a B18 block will be cheaper and machine work cost should be similar.
it will probably goin in a crx, that is stripped of a lot of things intended for track use.
please read the forum faq next time you post.
http://www.g2ic.com/forums/announcement.php?f=14&announcementid=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
