i know how to do it but are there any tips
so i can do it easier…
one thing is how the F&&& do you get thoese hangers on the reasonaor off
that shit is hooked so much it looks impossible!
thanks…
bout to do it in the morning
thanks…
push up on the exhaust piping will let the tension off…
then you can take the hanger off…
unbolt muffler, take out muffler, unbolt cat from downpipe, take out exhaust piping, then reverse to install…
I use wd-40 to help remove and install the rubber hangers. It makes slipping them on/off much easier. You could also use soapy water. wd-40 is just nice because you can spray it up where you need.
having a friend helps too since he can hold the exhaust up and you have 2 hands free to pull the hangers.
well i did it myself
god dam its a pain trying to lift the stock 1 piece piping
GRRRR
no wonder y i asked this dumb qestion…
i use to try to get the mounts off the piping
that was a no no since the hooks were curved
so the easy way was to take the mounts with the piping
aha
