can some one give me more ideas on how to loss more weight in my teg gs
i’ve gutted the interior, ac compressor/condenser, light weight battery… any sugestions?
thanx
sell it and get a RS
:werd: on the RS.
You can also pull your ABS and plug up the sunroof.
-nino
or you could be one of those nuts and put in fal’s :hump:
i’ve been wondering how to take off the abs for a while, what all would i need to do to take it off?
jdm bumper support?
where can i get it and how much is it?
I’ll ask this now, apparently there is a JDM rear bumper that also weights less
any info on this?
what info do you want? you explained it all, its for the rear, and it is lite.
well, how much lighter? the front one is about 20lbs lighter.
and… why is it lighter… is it just less metal, like the front JDM bumper support?
Exact a mundo… flimsy as all hell, but it will hold your bumper cover inplace. don’t look for crash protection
where can i get a jdm rear bumper support at? and about how much will it cost?
The front ones are pretty easy to find since a lot of people import front clips. The rear ones are extremely hard to find and I only know a few people that have them. Fronts go for $60-70 and the rears are much more expensive.
As for the ABS removal, search for “ABS removal” and you’ll find all the info you need(replace four lines with non-ABS equivelant, install proportioning valve, two custom lines, one 10mm to 12mm adapter for the rear connection at the master cylinder).
password JDM has rear bumper supports for g2 integras
