How compatible is the trannsmision from the B20A5 motor set up from an early generation USDM prelude with my B18a non OBD engine? I have heard that it wont fit and that it will fit from others and have done some research. some say that honda changed the molding for the block for the A5 ??? and though this is a B series block the bellhousing bolts differ from my gen 2 integra block. Has anyone successfully swapped an A5 cable tranny into their B18a?
Will this work(bellhousing to block and chasi to motor mounts)?
though the motor code starts with B, the B20A5 has almost nothing in common with the B series motors that come in the Integras. It might be possible to make it work, probably a pain though.
