Rotating turbo
Ok, so I FINALLY got my turbo from turbocalculator (NEVER buy anything from them) and the charge side of the thing is aligned so it would be pointing right at my radiator. Can I just loosen the housing bolts and change the orientation? Also I want the oil return line pointing down (not shown) so I’ll need to rotate the center also.
Chunk
Yep, just loosen the bolts and ‘clock’ everything in the place where you want it to be.
Just dont take any bolts all the way out.
sweet, I have that same manifold
Hey chump, I think you should run it like this
http://kentallman.com/paul/friends/Nate%20S%2092%20GS/turbo%20engine%20bay.jpg
chump
:loser:
If if doesnt clear the way I want it i’m gonna have to, there are only 2 possibilities.
Chunk
