oem headstud @ 6psi
oem headstud @ 6psi
    oem headstud @ 6psi
    would it be okay ?
    currently with 10.6:1
    will replace with arp headstuds when i get a new head and low comp. pistons.
    but that wont be for a while, so i'd be driving this daily @ 6psi.. so yea..
    yay or nay?
    17
    yay
    58.82%
    10
    nay
    41.18%
    7
    How ya doing Kevin! That's pretty sick you're boosting now. Congrats.
    Anyhow,
    Considering that our brittle aluminum Honda engines have no initial anti-knock countermeasures for boost, and that we've got floating aluminum cyclinders, I think FI B-series engines need as much protection as possible.
    And considering you're running 10.6:1 C/R.....eeeekkk! (Kaaaboom!) If you're not careful. (Also, what are you running for engine management, and fuel support?)
    IMO, B18c (longer version) ARP studs are worth the piece-of-mind, that your head has a smaller likelyhood of separating from your block. (Maybe overkill, but short of a sleeve-kit, I'd do block girdle, block gaurd, and all ARP fasteners.)
    My 2 cents. And congrats on the boosting Kevin. I'd like to see you're car again. Are you still rolling on the blue and red wheels?
    -Andrew
      you're fine at only 6 psi.
      but why didnt you use new head studs when you replaced the slugs?
      10.6 compression isnt all that crazy...just use more caution in the timing maps
        didnt change slugs, used a itr block, needed a motor, so i put together the vtec/b20
          What's your set-up kevin?
            ITR block, b20 head, 92 - 93 cams, fpr, short ram aem, dc 4-2-1 two piece, test pipe, and the rs*r. obd-0, stock ecu
              Why a non-vtec head? Also, what's your turbo specs? Also, why are you using a stock PR4 ECU to boost on?
              BTW, nice block.
                #8
                LS block broke, no money for vtec head, had parts laying around, so i made a frankenstein of my own.
                turbo specs, not sure.
                stock garrett T3
                from like, a ford turbo coupe.
                  #9
                  so u dont have vtec, u just got a super LS
                    #10
                    not even.. torque numbers are lower then a stock LS
