ok i have a built b16 (eagle rods wiseco pistons) yeilding about 9:1 compression i am reaching for a 300hp goal but this is a daily driver so i wanted something that spooled quick a friend can sell me a turbonetics turbo for only 150
specs
T3 turbine A/R 0.48 trim std
To4b compressor A/R 60 Trim v63
i need to know if this is a good turbo and around what rpm it will spool please some one??!! thanx.
ok thanks people as far as tuning is concerned i have hondata stage 2 dsm 450 injectors a walbro 255 fuel pump,AEM fuel rail and regulator and a 3bar map sensor… i’m going to have Payn Tech here in MI do the tuning for me so i should be fine and with the forged rods and low comp pistons i should be able to run more than 9 psi of boost man…tuning is the key…i’v seen people pushing 350-400hp with just forged internals no sleeving, detonation is what cracks sleeves and melts pistons so once i’m tuned good i dont think i have to worry that much for 300hp ok xenocron is your turbo is it a t04E or T04B cause i heard that the B’s spool faster just wondering…
Ok I Guess U Have Forged Pistons To I Would Say A Safe Whp Range No Sleevs Is Like 300 Or A Little More Would Not Push It To Much As A Daily Driver. Im Not Woried About The Pistons Or Rods The Sleeves Will Go First. Tune And Be Safe
