Interior Electrical help please!
1990 Integra RS
did a Headlight wire harness tuck. (all front lights work)
but now…
my RPM gauge isnt active. (tried swaping with another gauge cluster)
my clock only works when i hold down the tab.
and the turn signals wont blink (Hazards work)
this is really giving me a headache and all i know how to do is check all the fuses and they seem good.
Last resort, im going to take my dash back out and double check my connections and any short to ground… hopefully some body can help me narrow down my hunt.
thank you
OK, i double checked ALL my fuses and it was #10 Turn signal & reverse lights.
i replaced it but it popped again.
Then double check the wires. A wire is probably cut and shorting itself out on metal.
found the problem. the sleeves over my “Reverse sensor” was up and the metal was touching my mount…woow!
thanks mike
