A LOT of connectors identifications here, please help!
Ok so I’ve got a bunch of connector I can’t remember what they do, or where they go so I need your help to try to identify them. Here’s the first of 2 pic: (I’ll post the second when I’ll know where the connector of the first pic go)
  1. 2-Pins: Green/White - Brown
  2. 2-Pins: Blue/Black - Blue/White
  3. 4-Pins: Red - White - White/Red - Empty
  4. 8-Pins: Black - Yellow/Black - Red/Green - Green/Red - 4 Empty space
  5. 4-Pins: Blue - Blue/White - Blue/Black - Blue/Yellow
Voilà, Thanks in advance for the help
#2 blower motor
#5 Blower motor resistor
#1 I’m pretty sure this is the check engine light jumper. it is not connected to anything. You put a jumper wire between the contacts to flash the check engine codes on the cluster.
Thanks, found out about #2 and #5 this morning. Wasn’t sure about check engine light jumper.
#3 and #4 left…
Thanks!
