one piece headlights ??
i just picked up a set of jdm one piece headlights
and i installed them today.
i bought the jumper harness from passwordjdm to make it a lil cleaner.
this is the page for the part i got.
http://passwordjdm.com/PasswordJDM-DA-90-93-Integra-Headlamp-Jumper-Harness-P135C77.aspx
but now the low beams are on when the high beams should be on.
and when i flip the switch for high, the lows come on.??
has anyone used these jumpers before?
idk if they are side dependent.
i didn’t see any kind of marking on them.
has anyone else had this problem?
or is it common?
sounds like the wires in the jumper are backwards, if you can push the pins out of the harness connector and switch them. that should fix it
I have the same issue with the same harness. What do you mean push them out and switch them? Not following that.
The wires on the harness are not in the correct order. Some times if you get a tiny screw driver and push them into the harness the wire will pop out and just switch them around (except for the black one remains).
When i wired up my 1 pieces i got them mixed up so my high beams were low beams and visa versa.
Alright cool thanks.
i got this harness and there cool with me.
