headlights stay one when car is off ?Help!!
i turn the car off and the lights off and tmy headlights stay on and my high beams or low beams dont change sometimes it does this and sometimes it doesnt but my plastic handle is broken is this the wires for the handle ?
i disconected the battery and as soon as you connect it the headlights turn back on ???
Replace your “Combination Light Switch”.94
is there anyway possible i could fix mine other then glue’ing the plasitic back together ?? cuz none of the junkyards have these integra’s and im so outta money right now
Unlikely, because it is the park/head light switch, high/low beam switch, flash to pass switch and signal light switch, all in one casing, it is unlikely it can be repaired if it is the switch itself that is broken.
It may be possible to glue the lever back on with a good plastic glue, but that to would be tricky. 94
