Clock froze..
It stopped time at “3:55”, i reseted the battery…and now its frozen at “1:00”
im about to just replace it, unless somebody knows what the problem is and wants to tell me how to fix it!
If it stays at 1:00 with ign. switch on, [does not keep time] the problem is in the clock, to make sure, test for power at the clock plug…
black - ground
white/blue - 12V+ constant, [hot at all times].
red-black - illumination, [hot when park lights are on].
yellow/red - 12V+ switched, [hot in acc. and run].
If the above are good, replace the clock. 94
wow, thanks alot fcm always helping me out with electrical problems…hella glad ur an active member to this forum, thanks again!
I have the same problem! did you find what was wrong with yours???
Did you test the above leads? 94
Doesnt the clock have a tiny reset button on it.
