window motor
ive look everywhere but cant find how to take apart the door to get to the window motor.
my passenger side window is stuck up and i need to fix it asap. summer is here already and its gonna be hot. i do have a/c but i do like the windows to be down sometime to. pics of the process will be great.
SEARCH!:search:http://www.g2ic.com/forums/showthread.php?t=169915&highlight=windows
Are you sure it is the window motor that is bad. have you checked it?
Have you checked fuse 2 - 20A, [hot in run] in under dash fuse box?
Have you checked for power at both the drivers side pass. and pass. side switch, [blue/black lead at switch].
Have you checked the switches themselves, bad window switches are common on G2s.
There is a lot of simple testing to do before you spend the time and effort to remove the window regulators and swap the motors, a real PITA, even bigger if you do the swap only to find out it was not the motor in the first place.
Do you have a multimeter or a 12V test light? 94
