ok my problem is that i am putting a shift light in my 91 ls, its mounted int he cigar lighter cuz i figured that it would be easyer to wire up at the ecu… my question is does any one know exactly wich pin and wire color the tach signal wire is at the ecm plugs? any help would be great ive spent the last 3 hours looking online for it but with no luck…thanks
since your new…
read this:
http://www.g2ic.com/forums/announcement.php?f=33&announcementid=13
focus on this part:
BEFORE STARTING A NEW THREAD…
Please run a SEARCH before you start a new thread. The search feature allows you to find answers to your question / comment immediately, since it is VERY LIKELY that your question was asked before. Searching also reduces the site’s bandwidth requirements.
Should you still have questions, it is better to reply to an OLD THREAD than to create a new one.
If you need to create a new thread (such as the case with an archived thread), include a link to the thread where you got your information from and would like to continue the discussion.
DON’T BE LAZY, SEARCH FIRST!
and…
USE APPROPRIATE SUBJECTS
