ok so my problem just started a few days ago when i remove the key for some reason my ac lights come on after a few minutes and also i have my jdm one piece in and the fog lights hooked up to the defrost for the power Fallowed teg tips to do that and they come on if i leave the fog light switch on but when you take out the key they go off like normal but after a few minutes they come one with the ac lights help me please some one its crazy :bawl:
my running lights did that so i pulled the fuse and it solved the problem =)
well it solves the problem when the fuse isnt in
Ac Lights
Your problem is simple you have a bad ground. This happened to me and was fixed by simply replacing the ground from ther radiator support to the head. Hope this helps
