I hit my switch and they dont come on, all the lights work, switch is good, fuse is good, what else could be wrong???
Isn’t there a little flasher relay that causes them to blink. I think I have had cars just have the lights come on when you hit the switch and not blink, and it turned out to be the relay. Just a thought.
Were is it?
According to the Haynes manual it is “next to the steering column”. Although it does say that it is the same one for turn signals too. Are they acting up at all?
No the turn signals are just fine.
Did you chk the fuse on the battery cable? I had the same problem before, and that’s what I change the fuse there. HTH
I checked my fuse fuse box in my engine bay. It was all good. Otherwise I dont know what you mean?
not the one in the fuse box… the one inside the red cap on the battery’s terminal.
