system
1
My car is doing the following
car starts pretty well, sometimes fuel pump won’t prime and it won’t start.
when the car starts, I"ll let it idle dash lights are bright but my indiglos are messin up and look like they’re lackin power.
when I turn the headlights on, they are very dim, and each time I turn the headlights on, my temp guage goes up. but only when the car is on.
my hazards work, and my blinkers work too, but when the headlights are on the blinkers won’t work.
all the under dash fuses look to be in good condition, and all under hood fuses are good.
I reset the ecu and it didn’t change anything.
all the grounds are good and tight. I’m kinda lost, I guess I’ll tear into the dash tommorow.
fcm
2
For fuelpump check fuelpump relay, the next time you don’t hear it prime, give the relay a shorp tap the rest is probably a ground. 94
