hey just wondering if somebody could help me out…Well i was trying to fix the cig lighter in the car and im not sure if there was a spark or something but i go to drive the car later that night and the dash lights dont work anymore…just wondering if they are associated with eachother?The fuses were still good…I also took the gauges out to test for power and it was getting power…Also checks the little lcd in the guage cluster and they arent burnt out so im really stuck here…My headlights still work…SO if anyone could help it would be greatly appreciated thanks!!
come on
so what nobody has a suggestion?
Did you check all the fuses in both fuse boxs? the lighter is on a diff. fuse then the dash lights, do the parklights still work? if so, check that the dimmer control is still plugged in, and that it is still good, and just in case, is it turned up. 94
