i tried to rewire my fog light according to the teg tip , but when i did the job i forgot to dicconect the battery and now it wont work. Then tried method 2 which was running a wire to the fuse box on the driver side. frist it works but then immediately the fuse pop. then the second time i put in the spare fuse (7.5) it poped again… i want to do this light thing but having trouble … help plz thanks
Re-check ALL the wiring you modified. It is obvious that you have a short somewhere. Continuing to put fuses in is not going to work obviously; you have to find the actual problem.
Good luck…
