FM static w/ defrost
    basically the title says it....when my radio is on and i use the rear defrost it either i get complete static or it just sounds like shit...anyone?
    You have an ant. problem, a grounding problem probably. 94
      Check the ground wires on your antenna, and on your deck, and also double-check your main grounds (chassis to head, battery to chassis to transmission bracket).
      Make sure ALL those grounds are clean and good, and then try it again.
      Good luck
