yes i’ve searched and i can’t find anything (maybe using bad search terms ).
trying to find out if there is a city light inside the low-beam housings in jdm 1-piece headlights, and if so, is there a way of rigging the DRLs to run the city lights instead of the low beams?
also looking for pics of the 92-95 eg civic lighting harness/plug retrofit for these lights that are described in the teg-tips section of this site.
The civic harness is the same as the 1piece harness… it’s ment for an H4 bulb which is the exact same as an h4h except for the ring around the bulb that holds it in place… (the H4H one is smaller) Here’s the link to the 1piece install article i did… the last pic is a wireing diagram for the harness…
