Well i kinda want to upgrade my terminal, i have 2 amps, both running 8 gauge wires to the positive battery lead. The stock car wiring has 2 8 guage wire’s running to the lead. I’d like to get one of those fancy allen key ones to clean it up a little. But i can only find 4 hole ones with like 0,1,8,8.
Can i use the two 8’s, and stuff my amp wires into a 0/1?
http://www.stingerelectronics.com/web/prods/battery_terminals.asp
I just got some from stinger for my acura, the Small Multi Output. But i also got some for my truck from stinger, the Expert Digital & Expert. You can probably stick the 2 8gauge wires together in the 4 or 1/0 socket. I would solder them wires together to make sure they are good and solid, maybe not, but put some heat shrink on the ends to hold them together as 1 wire.
